Author Topic: Electrical Issue  (Read 3234 times)
Offline ssblu502
Electrical Issue
« on: September 13, 2009, 11:21:58 am »
I just put in a new starter and when I hook up the batery it arcs. Any suggestions. I have read through the threads but I have no clue. Thanks.
Big blocks Rule!
Offline Marc
Re: Electrical Issue
« Reply #1 on: September 13, 2009, 01:22:25 pm »
Sounds like it is shorting to ground.  I would check to see if the positive cable is touching ground anywhere, or if the cable is bolted correctly onto the terminal on the solenoid.  the top one away from the starter motor battery is the one the battery cable goes to...the other large one connects to the starter motor.  the purple wire goes to the small S terminal.  You could also have a bad starter.
Offline ssblu502
« Reply #2 on: September 13, 2009, 07:12:47 pm »
Thanks, I checked the battery cable and it was actually touching the S terminal.
Big blocks Rule!
Offline Marc
« Reply #3 on: September 14, 2009, 05:40:23 pm »
Perfect!  Thanks for posting back the fix!
