Author Topic: 700r4 & ls 5.3 questions.  (Read 5870 times)
Offline bk_cauley
« on: September 13, 2009, 07:10:30 pm »
does anyone know if i can use my fllexplate and convertor from my gen 1 motor, when i do my 5.3 swap. if not what balance, tooth count flywheel do i need to make it work. and can i use my convertor. does anyone know if the input shafts are the same.
Offline charris
Re: 700r4 & ls 5.3 questions.
« Reply #1 on: September 14, 2009, 12:34:30 pm »
I don't think you will be able to use the same flexplate.  I know the ones are different for the two piece rear main seal and the one piece.
Offline screamin86
« Reply #2 on: September 14, 2009, 01:27:56 pm »
you have to buy a $50 spacer/adapter for it to work. im gona do the same whenever i get to do my 5.3 swap in my k10. ill do some digging and see if i can find a link for you.
here you go i found it!!
http://www.summitracing.com/parts/HUP-HP3795/
« Last Edit: September 14, 2009, 01:31:01 pm by screamin86 »
86 ta:lm7 hot cam boltons
Offline bk_cauley
« Reply #3 on: September 14, 2009, 02:56:47 pm »
awesome. thanks man that is a mojor headache saver.
Offline screamin86
« Reply #4 on: September 14, 2009, 06:57:38 pm »
No problem
