Author Topic: factory drop hangers?  (Read 4336 times)
Offline MohterTrucker
« on: September 18, 2009, 11:40:53 pm »
Hello all, first post. Been lurking for a while but decided its time to add to the community (hopefully).
Anyway, I was looking at a later model (96ish) Suburban spring hangers and noticed that the springs mount higher (in relation to the frame) than the stock hangers by about 2". I wonder if anyone has successfully used these to lower their truck or if it is possible. If so, it would make for a nice cheap, factory lowering option.
« Last Edit: September 19, 2009, 12:05:19 am by MohterTrucker »
'83 GMC SWB 355: Iron Eagles 2.02/1.60's, 270/111LC, 1.6's, Edel/Weber 650, d/p mani, 1 5/8 longtubes, 700r4, and tired-ass factory rear leafs.
Offline N2TRUX
Re: factory drop hangers?
« Reply #1 on: September 19, 2009, 10:12:21 am »
I haven't seen anyone use the Burb mounts. I have seen guys remove the truck mount, cut the top down, and bolt it on a few inches higher up. Either way will work but you still need to add a lowering shackle. If not your pinion angle will be off by a lot.
