Author Topic: odometer  (Read 5714 times)
teeph
  • Guest
odometer
« on: June 29, 2002, 07:45:00 pm »
I have a 1979 4x4 chevy truck.  It has a six inch lift and 35" tires on it.  I know the speedometer doesn't read correctly because of the larger tires, but I was wondering if the odometer reads correctly and if it doesn't how can I figure how many miles I have actually driven compared to what the odometer says?
Offline 79mc
Re: odometer
« Reply #1 on: June 30, 2002, 12:51:00 pm »
The odometer will also be wrong. Search around the net the info you need is out there. If nothing else go to montecarloss.com,  click on technical, then speedometer calibration. The formula you want is there.
HTH's DougV>
