Author Topic: which plugs  (Read 4339 times)
Offline str8bloc
  • MISTRESS
which plugs
« on: September 21, 2009, 08:19:47 pm »
i have an 86 350 msd cap and rotor accel coil and vatozone wires r45ts plugs at .50'' should i get a different plug or change the gap?
FaTbOy
Offline malibu795
Re: which plugs
« Reply #1 on: September 22, 2009, 12:44:30 am »
sounds like a good start..
what is the specs on the accel coil?
volts
mA
and duration?
example this is what i run MSD blaster SS coil
http://www.msdignition.com/Products/Coils/Street/Strip/8207_-_MSD_Blaster_SS_Coil.aspx
Turns ratio: 70:1
Primary resistance: .355 OHMs
Secondary resistance: 4.4K OHMs
Inductance: 6.9 mH
Maximum voltage: 40,000 Volts
Peak current: 300 mA
Spark duration: 220 uS
if it fouls make the gap smaller.
or get wires with less resistances
adam wildman
75 K25 383/400
Offline str8bloc
  • MISTRESS
Re: which plugs
« Reply #2 on: September 22, 2009, 07:06:16 am »
its that accel coil that replaceces the coil and cover should i keep that gap
Coil Style  E-core
Primary Resistance  0.500 ohms
Coil Internal Construction  Epoxy
Coil Color  Gray
Maximum Voltage  45,000 V
Turns Ratio  80:1
Secondary Resistance  8.6K ohms
FaTbOy
Offline malibu795
Re: which plugs
« Reply #3 on: September 22, 2009, 08:43:57 am »
man i was hopeing to see how much mA it was pushing.
.050 would be a good start re-guardless
adam wildman
75 K25 383/400
