Author Topic: Is the glass the same?  (Read 4075 times)
Offline Skunksmash
« on: September 23, 2009, 02:55:18 pm »
Is the back glass the same on the '85, as it is on the '87? I found a solid back glass to replace my raggedy, run down sliding back glass. And for only $20. I am eager to buy it, but I know better than to do so without asking if they are the exact same. Anyone happen to know? My luck I would buy it and not have it fit, for some reason.
Re: Is the glass the same?
« Reply #1 on: September 23, 2009, 03:25:15 pm »
Its the same.  81-87 is the same thinner glass.  73-80 will work, but I would get another gasket.
Offline Skunksmash
« Reply #2 on: September 24, 2009, 01:30:48 am »
Do you think it would be possible for me to re-use the same gasket? Right now I have the sliding back glass, and I am wanting to replace it with a solid piece. Do the gaskets interchange?
« Reply #3 on: September 24, 2009, 11:54:46 am »
Depends on who made the sliding glass.  The factory supplied slider used the same glass.  Some aftermarket ones didn't.
Offline Chevalade
« Reply #4 on: September 25, 2009, 12:22:37 am »
Did gm ever make a factory smoked glass slider? I found one for $70 and am getting it. Just wondering if it is oem or aftermarket from somewhere.
