Author Topic: harmonic balancer??  (Read 5566 times)
Offline nativetexan
harmonic balancer??
« on: October 04, 2009, 10:45:52 pm »
Hey just curious... how do I install the harmonic balancer on my 87 small block. It is a oem replacement I picked up from autozone. It is a rebuilt motor so... any advice?
Let me know if you need any more info.
Offline Donut
Re: harmonic balancer??
« Reply #1 on: October 05, 2009, 06:40:11 am »
Reverse of the removal.  I'm not sure if AZ rents tools, but they "should" have an installation tool for the balancer.  Presses the balancer onto the crank snout.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline team39763
« Reply #2 on: October 05, 2009, 08:44:41 am »
I got these directions from SummitRacing.  http://static.summitracing.com/global/images/instructions/sum-161350.pdf
I know AutoZone and O'Reilly both rent out tools, but I'm not sure if they have the crank installation tool.  Maybe you could call and check.
« Reply #3 on: October 05, 2009, 09:23:55 am »
with a harmonic ballancer installer.
Offline SUX2BU99
« Reply #4 on: October 05, 2009, 12:13:02 pm »
Is it typical to heat the new damper up like those Summit instructions recommend to make it go on easier?
Offline team39763
« Reply #5 on: October 05, 2009, 12:27:38 pm »
I heated mine up in the oven at 200* for 30 minutes and just before I slapped the balancer on the crank I froze the crank-snout with a shot of nitrous.  I slapped it on as far as I could with a 2X4 and hammer.  Then I used the stock bolt to pull it the rest of the way.  Several other guys on the net suggested that the balancer be heated up to slide on easier.
