Author Topic: frame question  (Read 6209 times)
Offline olblue2
frame question
« on: October 05, 2009, 07:51:49 pm »
anyone else here have a 1977 k-20 4x4? was wondering theres a cross memeber piece on the frame rigt above the rear end that goes from one side of frame to other thats rusted pretty bad on mine. someone told me it was a fifth wheel brace somone installed?   was wondering if i can just take it out as wont use a fifth wheel
anyone? anyone?
Offline crazedhick3
Re: frame question
« Reply #1 on: October 05, 2009, 08:55:38 pm »
Ive got a '77.  do you mean the narrow piece across the back?  not sure what it was for but it was definately too small for anything like a fifth wheel support.  i took mine out.  i thought it was a support for the spare tire.  may not be the same piece you are referring to.
Offline olblue2
Re: frame question
« Reply #2 on: October 05, 2009, 10:13:06 pm »
nahh this piece is right over the rear axle. rusted bad on one end
Re: frame question
« Reply #3 on: October 06, 2009, 11:26:01 am »
Take a picture and post it.
There shouldn't be anything above the axle from the factory.  Is it riveted on or welded?
Offline olblue2
Re: frame question
« Reply #4 on: October 06, 2009, 05:33:53 pm »
looks bolted in, someone said it was a brace someone put in for a fifth wheel
but its right above the rear axle and it goes right across the top of the frame
Re: frame question
« Reply #5 on: October 06, 2009, 05:37:54 pm »
If it is bolted in It was added.
Offline oldwhity
Re: frame question
« Reply #6 on: October 06, 2009, 08:00:25 pm »
My 85 has one. It looks like a thick steel plate with a hole in the middle. In the bed there's just a hole and inside the hole there are threads for a ball. I'm not sure how it's installed because I never looked closely at it. I would remove it if it is bolted in.
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline 69byrd
  • Haulin!
Re: frame question
« Reply #7 on: October 06, 2009, 08:15:37 pm »
My 4x4 has one, a steel plate that a goose neck ball is attached to.
