Author Topic: Front fender emblem removal  (Read 11544 times)
Offline brewdogg
« on: October 07, 2009, 03:30:28 pm »
Holy crap :o How the heck do you remove the front fender emblems on a 79 K10? The engineer that came up with this idea must have been some kind of contortionist. Any suggestions?
Offline BLK86
Re: Front fender emblem removal
« Reply #1 on: October 07, 2009, 04:19:28 pm »
Try to remove the body bolts and pull the fender towards you.That may give you enough room to remove it.If not,your stuck removing the whole thing.I recommend using barrel nuts when installing  the emblems.That way you just push the emblems into place instead of using nuts.Good luck.
1986 K30 crew cab dually
454 cid
Offline oldwhity
« Reply #2 on: October 07, 2009, 04:22:18 pm »
I believe they're just pressed on. Use a putty knife and wiggle it under one side and pry just a little. Move it to the other side and do the same. Once it seperates from the fender you'll be able to see where the studs are and put the putty knife or pry bar next to it. Pry a little at each stud to be careful not to break the studs.
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline Donut
« Reply #3 on: October 07, 2009, 04:28:59 pm »
Mine were held on with a "speed" nut on the studs.  The only way to remove mine was to pull the fender.  They looked similar to thesehttp://www.thefastenerwarehouse.com/catalog/item/568857/216341.htm
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Online Captkaos
« Reply #4 on: October 07, 2009, 05:20:48 pm »
They are bolted on.  You have to remove them from the inside.
Offline oldwhity
« Reply #5 on: October 07, 2009, 07:52:52 pm »
Sorry bout that. I guess the older ones were bolted.
Rob G.
Offline hotrod24
1978 pontiac grand prix...
