Author Topic: 6.0l engine swap into '78 Chevy 1/2ton, 4x4  (Read 18780 times)
Offline BigRedDmax
« on: October 09, 2009, 11:30:05 am »
Ok, so I just joined the site today lookin for info on the previously mentioned swap. I think I have a great oportunity to pick up a wrecked '01 2500hd with the 6.0l engine for cheap. Im currently using my '78 Chevy 1/2ton 4x4 as my daily driver b/c I only live a few miles from work, but have future plans of  making it a trail/mud truck. I know the 6.0l will be far superiour on many levels verse the old 350 for on and off road driving. So just in the little I've been reading I've already got lots of great info on motor mounts, egine/trans mounting and exhaust. I've read a few posts where other guys have done this same swap. I was wondering if anyone could point me in the direction of futher info. Past posts, websites, magazines, any info will be very appreciated.  :) Thanks in advance guys, I already know my wife won't be, but Im sure glad I found this site! ;D
Offline modular93fox
Re: 6.0l engine swap into '78 Chevy 1/2ton, 4x4
« Reply #1 on: October 09, 2009, 11:45:32 am »
do you fear the search button... ive used google and yahoo and was pretty successfull when i did my swap.
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
Offline screamin86
« Reply #2 on: October 09, 2009, 12:10:55 pm »
Ls1truck.com! Its mainly nbs guys but there is info on swaps in older trucks aswell
86 ta:lm7 hot cam boltons
Offline team39763
« Reply #3 on: October 09, 2009, 01:44:20 pm »
I think I remember seeing a radix charged 6.0L in a older blazer(pre-73).  I bet it was one heck of a off-road-rig.  Maybe you could look into something like that.  Used Radix kits are going for decent prices these days and you'd have tons of power with decent gas mileage.  The swap isn't too bad.  I'd assume it's like any other motor swap, except you have to make sure you got the right parts for the job...right motor mounts to place your motor where you want it(in relation to the trans), right headers or exhaust manifolds, good sensors(MAP,MAF,cam,Crank, Oil pressure, Temp), etc.  Those are the things you need to consider ahead of time. Example: My first set of motor mounts/adapters set the motor 1" away from my stock TH350 trans, so I had to buy 1" setback adapters.  Next I tried a few different sets of manifolds and none fit, I had to ask around a bit to find a solution.  As far as the sensors and stuff goes, if you're gonna run the stock EFI, you need all the sensors and probably have the PCM tuned(get rid of VATS, Air bags, etc).  If you plan on running carb, just keep the cam sensor, crank sensor, MAP sensor + coilpacks with harnesses. The oil pressure and temp sensor may not need changed if you go with the EFI, but with a carb, you'll probably have to drill and tap the waterpump for the temp, and buy the adapter for the oil pressure.  Post up your progress and let us know how it's going for you.  The guys on here helped me and encouraged me through the whole swap process.  Good luck bro.
Offline BigRedDmax
« Reply #4 on: October 09, 2009, 04:00:32 pm »
I used yahoo, thats how I found this site, plus lots of other useful info...I just know from other forums that some of the best info comes from places like these and thought I'd just ask. Thanks for the advice in direction already guys.
« Reply #5 on: October 09, 2009, 05:57:54 pm »
Sounds like a fun project. I bet all of your questions could be answered right here.
« Reply #6 on: October 13, 2009, 02:45:31 pm »
A lot of info here, just ask some of us have completed this and some are in progress.
Offline team39763
« Reply #7 on: October 14, 2009, 08:36:06 am »
There was a fellow Texan looking into doing a turbocharged LSx powered monster truck a while back.  Maybe a correctly sized turbo kit on a 6.0 would work awesome for you...if a "all-motor" 6L doesn't do it for you.
Offline BigRedDmax
« Reply #9 on: October 14, 2009, 09:06:55 pm »
thanks guys! A supercharged 6.0l sounds soo awesome!
