Author Topic: Which P/S pump do I have?  (Read 5012 times)
« on: October 10, 2009, 03:08:31 pm »
How can I tell if I have a press fit, or keyway power steering pump? Its on a 1979 K10 V8. I couldnt find anything in the search.
Re: Which P/S pump do I have?
« Reply #1 on: October 10, 2009, 03:15:38 pm »
Key-way type has a nut holding the pulley on, press fit doesn't and is flush with the pulley.
« Reply #2 on: October 10, 2009, 03:26:42 pm »
This pic is a Key-way type
« Reply #3 on: October 10, 2009, 03:49:11 pm »
Here is a picture of a press on type
« Reply #4 on: October 11, 2009, 02:01:44 am »
OK, Ill take a look at my truck and check it out. I also read that there is also a metric version for 79+. Reason Im asking is because I might be interested in doing a March serpentine pulley conversion.
« Reply #5 on: October 11, 2009, 08:24:35 am »
Metric uses o-rings on the ends of the hoses.  Serpentine of newer style Chevy spins the waterpump opposite so you will need a waterpump and clutch fan off that setup if you go stock.
