Author Topic: something wrong with my alternator?  (Read 3591 times)
Offline gold84gmc
« on: October 13, 2009, 09:00:19 pm »
after my old alternator crapped to bed, i got a used alternator(only because it was cheap) and it makes a "whining" noise and the pitch gets higher with the rpm's, when i drive down the highway at 55 thats all people can hear when i go by, is a whining...i already tested it and its charging how its supposed to, so is there bearings inside that might be bad?
92 buick century custom 3.3L
Offline Layne
Re: something wrong with my alternator?
« Reply #1 on: October 13, 2009, 09:31:45 pm »
The bearings could be a little dry. I'd shoot them with a little wd-40
« Reply #2 on: October 14, 2009, 12:00:41 am »
it def sounds like bearings but if you do shoot with wd them its just prolonging the problem. also the wd will attract dust and dirt making the parts fail i would just go to the zone or something and buy a llt Warranty alt for 40-80 bucks
Offline gold84gmc
« Reply #3 on: October 14, 2009, 05:39:53 am »
also my belts squeel when the air is damp or if its raining, its not the alternator because it did it before i put that on, and it doesnt do it any other time, just when its raining or damp outside....theyre newer belts too
Offline Jim Rockford
  • Banned
« Reply #4 on: October 14, 2009, 09:02:05 am »
WD-40 isn't a lube and the bearings are sealed if its the newer style and if you tighten the belt too much  if its a v belt system, you will ruin the bearings .
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
