Author Topic: dumb questoin  (Read 6407 times)
Offline murraygmc
  • 85 gmc 4x4
dumb questoin
« on: October 16, 2009, 11:47:57 am »
what is the patern on a 85 gmc 1/2 ton , im goina put a 4 " roughcountry lift on  and thay recomend 35/12/50 tiers so i need to figure what size rim to buy  , im wanting to go with a good combo look tire and rim .....can someone help thanks
« Last Edit: October 16, 2009, 02:36:46 pm by murraygmc »
85 gmc high serria 4x4
Offline dv8customs
Re: dumb questoin
« Reply #1 on: October 17, 2009, 11:19:28 pm »
5x5
Offline Flamingbig10
Re: dumb questoin
« Reply #2 on: October 17, 2009, 11:49:02 pm »
I assume its a 4x4 then it would have a 6x5 1/2 and I would go with a wheel that has a 3.75 bs or less
Offline malibu795
Re: dumb questoin
« Reply #3 on: October 18, 2009, 05:22:55 pm »
man thats sticking out there... would be wise to get the steering box brace as well..
8-10" wide rims are recommend.. i have ran that tire on a 6.5" wide rim.. centers tend to wear faster...
i have had 16x6.5" with 5.125"BS rims on my truck no problem clearanceing the leave springs
and there is plenty of room ona  3/4 to run 15" rims
adam wildman
75 K25 383/400
Offline murraygmc
  • 85 gmc 4x4
Re: dumb questoin
« Reply #4 on: October 19, 2009, 05:41:51 am »
3.75 bs ? what dose that mean ?
Re: dumb questoin
« Reply #5 on: October 19, 2009, 09:10:12 am »
 it the distance from the inside lip of the wheel to the surface that bolts up to the axle
Offline malibu795
Re: dumb questoin
« Reply #6 on: October 19, 2009, 10:34:01 am »
yep with nothing else changes  the differnce between a 4"bs and a 3"bs is the wheel will stick out 1" farther on each side..
this will aslo cause increase scrub radius and force need to turn said tires.... cause more flex/pressure on all steering linkages..
adam wildman
75 K25 383/400
