Author Topic: How do you adjust the transmission/shifter linkage?  (Read 4832 times)
Offline team39763
« on: October 16, 2009, 08:20:07 pm »
I can't seem to get my shifter to work properly.  I went to take my truck for the first drive and was super disappointed(once again).  I owe it to my wife to give it one good shot down the track, then this truck is headed for the crusher - I give up on trying to make a fast truck.  I'll settle for a good looking cruiser.  Anyway, I tried adjusting the linkage where it connects to the trans, but it doesn't seem to have enough adjustment to for me to set it for neutral without just leaving the front hex nut completely off.  I don't know what I'm doing wrong, it's the same motor, same trans, same shifter.  Only thing that changed was the manual valvebody.  I was careful to make sure I put the shift lever back where it was when I did the swap.  Anybody have any advice?  I really needed this truck to be driving by tomorrow for a car show.
The trans is a TH350, the shifter is a Hurst Pro-matic, the valvebody is a ATI Compu-(something).  Maybe the reason I was disappointed was because it was taking off in 3rd making it less than impressive?
Offline team39763
Re: How do you adjust the transmission/shifter linkage?
« Reply #1 on: October 16, 2009, 09:33:04 pm »
I got it partially adjusted, but after the first try(after adjusting) it needed gas to engage each gear.  What should I be looking into now?  More linkage adjustment or more fluid?
Offline team39763
« Reply #2 on: October 17, 2009, 12:13:39 am »
Now that I think about it, my truck didn't have that bog off idle that it used to have.  I'm kinda impressed with that.  I'm gonna take it out tomorrow for the car show if I can get it to go through the forward gears.  Now I just have some electrical gremlins to figure out.  I still would like some suggestions as to why the engagement is delayed.
Offline team39763
« Reply #3 on: October 18, 2009, 11:00:00 am »
Everything is sorted out now and the truck is driving decent. Here's the video I posted in my project thread.  The driver was too scared to get on it, so he did a little part throttle launch.
http://s46.photobucket.com/albums/f143/team39763/?action=view&current=100_0102.flv
