Author Topic: Parking Cable Removal  (Read 7286 times)
Offline billywilly92
« on: October 17, 2009, 08:23:57 pm »
I am trying to remove the parking brake in my 1986 chevy because I want to replace it. I bought a new front line but I can not figure out how to remove the line off of the pedal bracket. How do I remove it?
Re: Parking Cable Removal
« Reply #1 on: October 20, 2009, 09:26:17 am »
Someone has to know. Could you move this into the appropriate area if this is the wrong section.
Offline j250trxr
  • 1 tons rule
« Reply #2 on: October 20, 2009, 10:58:58 am »
the easiest way is to loosen the 2 nuts in the engine compartment and the 1 inside the cab,then once the cable is loose there is a cap i guess you would call it that is attached to the cable this has to be unclipped then pulled out backwards through the holder
Offline hotrod24
« Reply #3 on: October 20, 2009, 09:08:35 pm »
cut it that the best way if you are replacing it
1978 pontiac grand prix...
« Reply #4 on: October 21, 2009, 05:05:59 pm »
I have the cable cut right after it goes outside the cab. I just can't figure out how to remove the cable off of the pedal bracket. There is this weird clip that has three prongs on it and I don't know how to get it off. Everything is all covered in mud so now its a little rusty which might be making it a problem.
Offline hotrod24
« Reply #5 on: October 21, 2009, 05:35:50 pm »
post a pic
« Last Edit: October 21, 2009, 05:41:22 pm by hotrod24 »
Offline hogdaddy
« Reply #6 on: April 13, 2010, 09:59:07 pm »
Use a box end wrench that will just slip over the metal piece (I forget what size but I just did this) and apply some pressure and wiggle it and it will release.
This also works on the other end on the backing plate of drum brakes.
« Last Edit: April 13, 2010, 10:02:02 pm by hogdaddy »
