Author Topic: what panel do I need  (Read 4504 times)
Offline BOCEPHUS
« on: October 18, 2009, 01:21:34 pm »
what repair panel or panels is needed to repair the pinch weld , were the door to cab seal goes . (see photo)
Offline BOCEPHUS
Re: what panel do I need
« Reply #1 on: October 18, 2009, 06:34:04 pm »
I thought I was the only one who did not know.
is it made on the rocker panel, the inner rocker or the floor ,
it has to be one of the three ,
Offline jaredts
« Reply #2 on: October 18, 2009, 07:26:22 pm »
The replacement rocker (outer) has the weatherstrip lip in it.  Chances are if you get into replacing it you will find you need more than that, though.  Its tough to know where to stop cutting out rust without getting it all.  If you're not willing to get into a project that big I wouldn't cut the rocker off.  Just weld in a piece to replace that part of the lip.  If you are willing to cut out panels and weld them in, then inspect the inner rocker (from under the truck) and the cab floor support.  Chances are you'll need them.  And maybe part of the floor and maybe the cab corner and maybe the footwell.  I can tell you from my current experience repairing my cab you'll find more that needs replaced than you think--and its a big job.
Offline Donut
« Reply #3 on: October 18, 2009, 07:33:54 pm »
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=0850-101-102&Category_Code=C1
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5661.0  Check here, you can decide exactly what you need.
It's not a matter of not knowing, but how do you want to skin this cat?  Is it just the lip, whole rocker, floor and rocker?
If it's just the lip, I'd consider welding in just a piece of sheetmetal, but then again I've been known to make a hack look like a professional.
I type even slower than I work. (lol)
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline BOCEPHUS
« Reply #4 on: October 18, 2009, 07:57:18 pm »
thanks
