Author Topic: fuse panel  (Read 9706 times)
Offline aussie
fuse panel
« on: October 18, 2009, 05:30:41 pm »
this might seam like a silly question but here it is !!!
how does the fuse box get it power i know its from the battery but where does it go before the battery and what color is the wire , size, etc i know the wire for the starter is purple but thewre is that red one that goes to a juction box on the upper fire wall too!!!
Offline Marc
Re: fuse panel
« Reply #1 on: October 18, 2009, 05:48:23 pm »
There should be two red ones on the starter connected to the power terminal...one fusible link goes to the headlights, and the other goes to the fuse panel IIRC.
Offline aussie
Re: fuse panel
« Reply #2 on: October 18, 2009, 06:59:34 pm »
ok i see 2 wire coming off the block 1 wire thick that the other has a ring on it  but before the ring has a cclyinder shape platic boot on it
the second on the block goes in a splice and then one goes to the block on the firewall the other 2 go to a smaller ring and a push on terminal
Offline aussie
Re: fuse panel
« Reply #3 on: October 18, 2009, 07:27:41 pm »
here is what i mean ?
Offline Flamingbig10
Re: fuse panel
« Reply #4 on: October 18, 2009, 09:56:46 pm »
I think the one that you have market for the starter goes to alternator
Offline aussie
Re: fuse panel
« Reply #5 on: October 19, 2009, 08:15:59 am »
right!!! im sure you are right!!!! thanks
Offline aussie
Re: fuse panel
« Reply #6 on: October 19, 2009, 05:43:50 pm »
ok  guys here whats going on i have the red wire from the block the goes to the starter hooked up then the gig cale from the starter to the battery hooked on the same tread  on the starter i have the purple wire from the firewall connector block hooked up to the soilniod terminal on and it wont crank nothing
i got under it and someone was cranking over and i check to see if i had 12v nothing and im sure it was -033 or something!!!! any idea what would stop it from canking
Offline Jim Rockford
  • Banned
Re: fuse panel
« Reply #7 on: October 20, 2009, 11:48:38 am »
the one you have marked battery goes to the positive cable terminal of the starter.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Offline aussie
Re: fuse panel
« Reply #8 on: October 20, 2009, 08:00:29 pm »
yup Flamingbig10 mention that in an earlier post i found out the purple wire that goes to the soilniod does not have 12v cranking so i checked on rear of the fuse box where the purple wire comes out and i dont have power there either i checked fuses all good i made sure it was in park still no power i checked in neutral nothing its stumped me
Offline aussie
Re: fuse panel
« Reply #9 on: October 21, 2009, 07:59:13 pm »
ok its cranking now that 5.3 should be about ready to start by the end of the weekend
Offline bagged81
Re: fuse panel
« Reply #10 on: October 22, 2009, 08:05:40 am »
Not to hijack, but what is the purpose of the black junction block for the wire that goes to the starter?
Jeff C.
1981 Silverado - bagged, z'ed and 20's
Offline Marc
Re: fuse panel
« Reply #11 on: October 22, 2009, 09:01:13 pm »
I hooked auxilialry electrical devices to it - power to the trailer brake controller and power to the back of the truck for the trailer.
