Author Topic: 87 GMC sm465 to nv4500  (Read 50533 times)
Offline 87GMC
« on: October 20, 2009, 03:49:00 pm »
Alright, so I have done as much research as possible and I'm at a road block.  I have a 87 GMC v2500 4x4, 350 tbi, sm465 4 speed, and a np208 tcase.  I am looking at changing over to a nv4500 5 speed.  From what FACTUAL info I have gathered, the GM nv4500 will bolt directly to the np208.  Where I am getting stuck is will the GM nv4500 bolt directly to the 350tbi and allow me to use my stock bellhousing and hydro clutch setup?  The 350tbi's were all the same from 87-95 so engine side should be fine, it's the tranny side that concerns me.  Also, 88-95 had a passenger side clutch slave, as the 87 had it on the driver side.  Has anyone ever done this, or what adapter(s) will I need.  I would like the OD for the old truck because with 172,000 miles, its still gets 16mpg, OD would just be the icing on the cake.  Any info would be helpful.
1987 GMC V2500 Sierra Classic 350TBI 4 Speed 3.42 Gears
2002 Chevy Camaro Z/28 LS1
Re: 87 GMC sm465 to nv4500
« Reply #1 on: October 20, 2009, 04:47:48 pm »
The bolt pattern on the SM465 is narrower than the NV4500.
« Reply #2 on: October 20, 2009, 07:43:19 pm »
Below is a copy and paste from an email I got a few days ago...  I hope it is not out of line to post this up.
Brand New NV4500 5 speed 1T truck trannies and conversion packages available
We are still able to supply Brand New NV4500 transmissions. NV4500s are generally recognized as the best 5speed transmission ever supplied in a light truck. They have become popular conversions in older or light duty pickups wanting to upgrade. They are also popular conversions where going from auto trans to stick is desired.
They are available both in GM. Dodge standard duty, and Dodge Heavy Duty (Diesel and V10 apps). 2WD or 4WD. All have the late style parts, with the correct upgrades as needed for 5th gear retention.
A Brand New, dyno tested NV4500 is $2117, complete. No core charge. Figure $125 freight, continental US.
We can also supply custom configured NV4500s, for example: GM in front, Dodge in rear, or Dodge HD in front, GM 4wd in rear. Same price as above. We can still supply NV4500s with the GM 6.34 ratio 1st gear ($100 extra). We can overbuild NV4500s for 600+ HP Cummins apps.
We can supply conversion packages to install an NV4500 in Dodges, Fords, GM, Jeeps, Land Cruisers. Diesel or Gas. Packages can include clutches (we carry SouthBend, Luk, AMS, etc) Bellhousings,  flywheels, precharged complete master-slave setups, as needed. We have adapters to use NV4500s to replace Ford 4speeds, mate up to Ford transfer cases, mate up to GM NV4500, mate up to Toyota transfer cases, all sorts of stuff. Check out the web page for more data and tech info on the trans:
http://www.high-impact.net/transmission_and_gear/nv4500.htm
Call or e-mail for a package quote!
Greg Miller
High Impact Transmission and Gear
greg@high-impact.net
Ph: 888-316-2940
Offline 87GMC
« Reply #3 on: October 21, 2009, 11:31:42 am »
Thanks for the info.  Do you know if I can modify my factory bellhousing or who makes a kit(bellhousing and adapter) to adapt this tranny.  I already plan on spending about $1200-1500 for the tranny and rebuild.  I would like to keep this realistic, otherwise it's not worth the swap.
« Reply #4 on: October 21, 2009, 11:47:45 am »
Why not just use the bellhousing that comes with it.  It will bolt up
Offline 87GMC
« Reply #5 on: October 21, 2009, 02:59:09 pm »
The only problem I have with that is trying to figure out the stock 87 master(threaded fittings) to the 92-95 slave(plastic line oring fitting).  I would also run into clearence issues with the starter I think? ??? I just really wanna know if I can keep the slave setup on the driver side, as it would make life easier.
« Reply #6 on: October 21, 2009, 05:54:50 pm »
Why would you have starter clearance issues?  Both bellhousings are mounted to a SBC.
You could always get some lines made.
Offline 82oldskid
« Reply #7 on: October 23, 2009, 03:04:10 am »
hey, i'm kinda in the same boat, here!  got an 86 K20, with a 4bbl 350, and a 400 auto trans.  i came across a good deal on a tranny, and with it came the flywheel, clutch kit (its like brand new), master cyl, slave cyl.  only thing is, its all from an 88-up truck.  what of this stuff will work for me?  also, what will i need to buy?  help, please!
Offline 87GMC
« Reply #8 on: October 23, 2009, 01:53:41 pm »
You will need a pedal setup out of a 85-87 pickup.  I am pretty sure you will have to buy an adapter bell housing.  I would check out www.advanceadpters.com or www.novak.com.  You will also need a master off of a 85-87.  The cross over line will screw into the 85-87 master and it will have a factory fit, which will be easier for you to install.
Offline grandfisher
« Reply #9 on: January 15, 2010, 08:11:24 pm »
If you guys need any info, I just did this swap.  I started with a 1976 C2500 Crew Cab with TH400 and 454.  I converted it to 4x4 and added the NV4500.  The Nv4500 WILL bolt up to an N2P208 that was originally behind an SM465.  Unless you want an internal slave, you'll need to buy a bell housing.  I got mine from AA.  A bell housing from a SM465 will not bolt up to a NV4500.  At least not the 1996 and later Nv4500.  If you have 4x4, you wouldn't want the passenger side slave because it occupies the space that the 4x4 driveshaft wants to be in.  If you had a little lift you might be alright.  It's a fairly easy swap.  If I can help at all let me know.
1976 Chevy Crew Cab K2500
  4x4, NV4500, NP208, 454, 7:73 Gears
1987 Chevy Silverado C1500
  5.7L, SM465, 3:08 Gears
Offline frito-bandito
  • Hillbilly Deluxe
« Reply #10 on: February 04, 2010, 07:51:17 am »
How much do the adapter bellhousings cost on average?
« Reply #11 on: February 04, 2010, 09:44:14 am »
No idea, Google Advance Adapters.
Offline cubicdollars
« Reply #12 on: February 04, 2010, 05:20:20 pm »
I have a Factory NV4500 Bellhousing still attached to my NV4500 on a stand would everyone like to see photo's?  It came out of a 94 Chevy 1 ton Diesel , it has the same bellhousing pattern as a Small block and Big Block but the bellhousing to transmission is slightly different than previous trannys.
« Last Edit: February 05, 2010, 05:38:55 am by cubicdollars »
« Reply #13 on: February 05, 2010, 10:58:25 am »
Thanks Cubicdollars.  You can see the difference in the NV4500 bell is the clutch is on the opposite side, still doable.
