Author Topic: spring bolts  (Read 3981 times)
spring bolts
« on: October 24, 2009, 02:43:04 am »
OK i cant seam to find the spring eye bolts anywear ace hardware even napa, next bet it lowes. but my next problem is shock bushings. i got aftermarket shocks about 6 years ago had them sitting along with a lift kit after putting the lift kit in i went to do the shocks only to find (a). i lost 4 out of 8 shock bushings or (b).they were never sent but eather way the only ones i can seam to find are in autozones help section and they only carry one they have one advace has one but its also the bolt that i don't need so its about $5+ for each one plus i have to run to a couple diffrent stores to find them.
Re: spring bolts
« Reply #1 on: October 24, 2009, 10:56:25 pm »
Any speed shop. or decent parts store can order you the correct bushings. Just have to find a parts guy, not a look it up by application key board puncher!
Re: spring bolts
« Reply #2 on: October 28, 2009, 02:06:47 am »
well the bolt i ended up getting from a spring shop that works on big rigs. and the bushings well lets say i went to autozone and bought 4 cheap springs with lifetime warranties and took the bushings off them and we will see what happens to them  ::)
