Author Topic: EGR Manifold on non-EGR engine  (Read 4720 times)
Offline o2man98
« on: November 02, 2009, 04:02:19 pm »
I have a 1981 GMC C20 with 350 and an Edelbrock Performer EGR manifold. There is no emission equipment on the truck but the manifold has a simply steel threaded plug where the EGR valve should be. Is this the correct way to block the EGR in the intake?
Offline eventhorizon66
Re: EGR Manifold on non-EGR engine
« Reply #1 on: November 02, 2009, 06:09:21 pm »
The EGR is usually blocked off with a plate.  I'd say if it doesn't leak a NPT plug is OK too.
http://www.summitracing.com/parts/WND-9007/
« Last Edit: November 02, 2009, 06:13:21 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline Jim Rockford
  • Banned
« Reply #2 on: November 05, 2009, 01:25:56 pm »
Problem is there are 2 ports for EGR the one coming from the exhaust crossover and the one going to the Intake plenum, If just the exhaust side is threaded and plugged , you will still have a major intake leak . so that is why people use a plate , it covers both ports.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Offline o2man98
« Reply #3 on: November 05, 2009, 05:30:07 pm »
The manfold still has the plate that the EGR valve itself screwed into. It looks like the EGR valve was unscrewed and a plug put in. I do not see any other hole in the area.
  • Banned
« Reply #4 on: December 11, 2009, 10:04:20 am »
Not really getting what you are saying...got any pics?
