Author Topic: Reman steering box  (Read 5030 times)
Offline dblxx
Reman steering box
« on: November 03, 2009, 06:19:47 pm »
 Just put in a reman steering box 2 days ago. As far as I know I bled it properly, had it on jack stands turned it both directions
for a while and then some. It is full of fluid. The problem is it turns a little harder to the left a little easier to the right. It drives
a lot better than the old box. I hesitate to return it because I believe it's a crap shoot with reman stuff, but if this is a bad
situation I will. Is it?
Re: Reman steering box
« Reply #1 on: November 03, 2009, 09:42:40 pm »
I would make sure that your steering is not binding with the truck's front wheels off the ground.  If that checks out I would return the box, it is not supposed to be that way...
« Reply #2 on: November 04, 2009, 08:22:39 pm »
Did you cycle it with the wheels off the ground?  Is there air in the pump?
Check the suspension pieces for binding like zieg said.
Offline dblxx
« Reply #3 on: November 11, 2009, 10:35:28 pm »
Ok I return that steering box. The next one leaks, leaks a lot. Take that one back. #3 after 50 miles seems perfect!
« Reply #4 on: November 11, 2009, 10:45:25 pm »
That's encouraging...
