Author Topic: 6" lift question  (Read 4768 times)
6" lift question
« on: November 04, 2009, 08:16:40 pm »
I have a 79 K10 with a 6" lift with a 4" steering arm. I see that there is a 2" pitman arm and 2" draglink available for the truck to help even more with the steering. Besides the price difference, which route would be better?
Offline 1HI4x4
  • V30 Crew now a shortbed.....
Re: 6" lift question
« Reply #1 on: November 05, 2009, 05:20:22 am »
I would do the pitman arm if I was going to do anything, but with the steering arm already installed you should be about as good as stock.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
« Reply #2 on: November 05, 2009, 10:04:03 am »
Superlift and Skyjacker both say to do it for best results.
Offline 1HI4x4
« Reply #3 on: November 05, 2009, 12:55:39 pm »
That's because they sell parts for a living,....... I have 6" lift and just the steering block(dana60) and my truck turns just as tight to the right as it does to the left. That's how you know if it's needed, the steering will be sharper to the left than it is to the right.
