Author Topic: door swap  (Read 4374 times)
Offline k5blazerfan
  • K5 blazers will never die
door swap
« on: November 09, 2009, 02:43:29 am »
i have an 84 k5 blazer it cam with power windows and locks someone had cut the wires going to the door and put new doors with manual windows and locks i was wondering if someone had a wiring diagram for this or if someone new were the wires went under the dash and if they had a release on the harness any info would be greatly appreciated thank you
Don't forget the tow chain!!! Might have to tow a ford home! :)
Re: door swap
« Reply #1 on: November 09, 2009, 05:59:46 am »
The wire run right to the fuse box and plug in. You can get the harness new , but I would find a donor truck at a salvage yard. Probably an hour or two job to install.
Offline k5blazerfan
Re: door swap
« Reply #2 on: November 25, 2009, 01:22:47 pm »
yeah i found 2 really good doors at the salvage yard with power windows and locks.. i also discovered you follow the wires from the door to under the dash theres a harness there that unplugs so you can plug in the new ones
