Author Topic: Butt welding body panels  (Read 6172 times)
Offline got2haul
« on: November 09, 2009, 08:00:13 pm »
I'm going to cut out and replace a section of damaged panel on a bedside.  Having never done this before, do I need to have a gap between the panels where they will be welded together, or should the panel edges be touching one another?  My guess is that there should be a gap, but I'm not sure.  If there is a gap, approximately how far apart should the edges be?
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Re: Butt welding body panels
« Reply #1 on: November 09, 2009, 09:08:28 pm »
They should be touching.
Offline devious
« Reply #2 on: November 10, 2009, 12:15:51 am »
i agree...and when you grind the weld down dont hold the grinder in one spot for to long it will distort/warp the panel, just skip around from one side to the other
Offline joesgarage71
  • Wrench
« Reply #3 on: November 10, 2009, 10:44:00 am »
I use a flange tool on the bed side edges and cut the patch to fit. weld a inch every 8 inches cooling with a rag and water till its filled. grind and a little body filler.
Butt welds are harder, your patch better be good.
Offline emr_09
« Reply #4 on: November 10, 2009, 07:02:11 pm »
This is the way I do it. Make sure you get epoxy on both sides and I would highly recommend using the short strand fiberglass filler by evercoat. It is waterproof where the regular body filler isnt.
79 GMC Shortbox 4x4
383stroker/350t
83 Chevy Shortbox 4x4
350/350
