Author Topic: Height after lift  (Read 8952 times)
Offline krafty33
Height after lift
« on: November 16, 2009, 08:56:05 am »
Can you guys tell me what your vehicle height is after a six inch lift with 33 inch tires. I am looking at the height from the ground to the top of the cab. I just need to know if I will be able to get mine out of the gargage after the lift. I have a 76 K10 longbox
Offline thirsty
    • Suitor's Garage
Re: Height after lift
« Reply #1 on: November 16, 2009, 06:43:09 pm »
Wish I had a cab on mine to measure it for you, but I can tell you that I have a 4" lift and 33's and that is all I can fit in the garage with a standard size bay door. I have to hold the door up to get it in.
Offline Chevalade
« Reply #2 on: November 16, 2009, 07:01:25 pm »
And if you have a 6" lift and 33's it is going to look dorky....you will want 35-44's with 6" of lift.
« Reply #3 on: November 16, 2009, 11:52:18 pm »
i know on my buddys blazer with 4" and 38's we had to air down the tires a good bit to make her fit
Offline bryco3
« Reply #4 on: November 17, 2009, 04:50:16 pm »
If your throwing on 33's you better go with a 4in lift. A 6 in would just look goofy with that tire size.
Here's a pic of my k10 with 6 in lift and the old 33's on her.
here she is with 35's and  6 in lift
Offline krafty33
« Reply #5 on: November 17, 2009, 09:15:15 pm »
Pictures are worth a thousand words
Offline Wardog
« Reply #6 on: November 21, 2009, 11:05:10 pm »
My 78 Blazer has a rough country 6" lift, 33" tires on 8" wide rims.  It measures just under 7 ft from the ground to the top of the cab.
