Author Topic: Leaf spring lengths  (Read 31723 times)
Offline krafty33
Leaf spring lengths
« on: November 17, 2009, 09:23:04 pm »
What was the difference between models with the 52" inch springs and the 56". Was it certain models?
Re: Leaf spring lengths
« Reply #1 on: November 18, 2009, 01:57:16 am »
i think it was due if it was hd or not or maybe how many leafs it had
« Last Edit: November 18, 2009, 02:01:00 am by Irish_Alley »
Offline Chevalade
« Reply #2 on: November 18, 2009, 07:18:12 am »
Shackle location, front rotor width, and amount of leaves in pack are the differences. Afaik
« Reply #3 on: November 18, 2009, 11:31:35 am »
rear hanger location, amount of leaf (spring capacity) and Load rating.
Offline Jim Rockford
  • Banned
« Reply #4 on: December 17, 2009, 06:06:50 am »
Bringing this back to the top, I got a good line on a 3/4 ton rear with springs, . if the length of the springs are wrong I can still bolt the rear to my stock 1/2 tons spring correct?
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
« Reply #5 on: December 17, 2009, 10:17:01 am »
so your asking can your 1/2 ton bolt to the 12 bolt yes
« Reply #6 on: December 17, 2009, 11:27:26 am »
Yes the rearend will work under the 1/2T.  the only difference is the rear hanger location.  The axle location is the same.  3/4T springs were an option on 1/2T trucks making them Heavy Half/ HD versions.
  • Banned
« Reply #7 on: December 17, 2009, 02:53:46 pm »
Yea thinking of doing a LT1/th400 and 3/4 rear for a decent  tow vehicle. possible to move the front hangers forward  for the longer springs on a short bed? I looked  but I really didn't see any of the extra holes that lined up.
« Reply #8 on: December 17, 2009, 03:50:10 pm »
You move the rear hangers BACKWARDS to for a SWB 1/2T.  Should have the holes there already.
  • Banned
« Reply #9 on: December 17, 2009, 04:10:59 pm »
Thanks I'll check tomorrow.
Offline kurtdirt1
« Reply #10 on: December 31, 2009, 09:58:58 pm »
so if a 1/2 ton is a heavy half it'll have 52" leafs? my glovebox says "hd rear" and it's a half ton. or it says "hd leafs" can't remember. My 86 has 52" leafs but i have an 85 with 56" leafs (both 1/2 tons) . they both have 5leafs but the 52" leafs have an overload looking leaf and the 56" just has 5 long looking leafs
86 SWB 2wd Silverado Bone Stock
Offline kurtdirt1
« Reply #11 on: December 31, 2009, 10:06:41 pm »
Did a search and came up with this
52" reg half
56" heavy half
that sounds weird imo. wouldn't a shorter leaf have more strength or am I thinking backwards.
my 85 GMC Sierra Classic has 56" leafs
my 85 Chevy Silverado has 52" Leafs
So does that mean that the rearend out of the 85 is HD as well? The 85 has a rear sway bar but my 86 doesn't.
Offline Torque454
« Reply #12 on: January 02, 2010, 03:59:13 am »
My 79 1/2 has 7 leaf 56" springs and the 86 3/4 ton frame i bought has 8 leaf 52" springs on it. I don't really see a pattern, its almost like they just said "hey lets put 56s on this truck and 52s on that one!"
The holes are in the frame for both spring mount locations. I'm going to likely use the 8 leaf springs under my 1/2t with the 14 bolt 4.10 FF axle. I am also going to mount the front suspension from the 3/4 ton to my 1/2t.  I dont have the ability to lift the body off my 1/2t frame to place it on the 3/4t frame unfortunately.
« Reply #13 on: January 02, 2010, 10:42:45 am »
Heavy duty means suspension only not the rearend.  Longer springs generally have more leafs not sure why yours both have 5, as the HD version should have 7.
Offline kurtdirt1
« Reply #14 on: January 02, 2010, 01:46:59 pm »
I'm assuming the PO took a few leafs out. The 85 "hd" is lowered (what some people do awes me, lowering a work truck)
