Author Topic: Rebuilding my 87  (Read 155957 times)
Offline fptransport
Re: Rebuilding my 87
« Reply #120 on: March 28, 2010, 10:45:48 pm »
good to hear you got it turn in... as for the driveshaft, I dont know how much it goes in, but once i drop the tranny down, it looked like it when into the trans, just as much as it was with the original trans, by seeing the "wear marks" on the yoke...
Offline 87OldYeller
« Reply #121 on: April 19, 2010, 02:28:24 pm »
Well no progress made over the past few months the Coast Guard has had me bouncing all over the map. But I am back in Tn. another 2 weeks and I can get back home and work on my truck some. I did get another computer for it as that seems to be why it will not stay running. Truck will fire run about 5-8 seconds and stumbles and falls if you try to accelerate it wants to stay alive but dies. I got the OBD2 port hooked up and it is reading codes for the drive by wire set up so I guess it was not properly deleted. The new computer is OEM for DBC, just have to get it tuned and maybe that will fix my problems.
Offline 87OldYeller
« Reply #122 on: May 10, 2010, 12:11:23 am »
Anyone that has done this swap. What did you do to connect the OEM for the truck shift linkage to the transmission. 4L60E
Well I am still on the road right back in Tn. been here for a month and I leave here on 11May2010 and go some where on the gulf coast to watch the oil... So I have done nothing with my truck.
Offline 123 pugsy
« Reply #123 on: May 10, 2010, 05:13:31 am »
Did you try bolting the u bracket from your old tranny to the 4l60e.
It shoud fit on the shift rod.
Pugsy
76 C10 LWB
TPI 350
Offline 87OldYeller
« Reply #124 on: May 10, 2010, 07:33:36 am »
naw i dident I let the old tranny got with the motor but i have another one i can get the linkage from.. thanks
Offline 87OldYeller
« Reply #125 on: July 26, 2010, 08:59:44 pm »
I am needing a little help. I finally got back to working on my truck. I got it running, It will fire up run but will not Idele, as long as you stay in the throttle it will run. Here is the kicker, had no exhaust to speak of just down pipes. Will this engine run with out cats? I have OEM cats that were on it I just don't want to use them unless i have to. There are no emission laws here so no worries about that. I am gonna have full exhaust put on with maybe just some flowmaster 40's.
« Reply #126 on: July 26, 2010, 09:14:22 pm »
Check the choke, check for vacuum leaks, set the timing.
Offline 87OldYeller
« Reply #127 on: July 26, 2010, 09:29:16 pm »
ok .. timing should be ok i think we were driving the truck on a daily basis before we pulled the engine. I will check for leaks in vacume. what is there to the choke on the LS1
« Reply #128 on: July 27, 2010, 02:40:10 pm »
Is this the LS motor that is EFI?
Offline 87OldYeller
« Reply #129 on: July 27, 2010, 04:59:36 pm »
yea.. fuly stock 2002 5.3L nothing have changed on or in the engine. But i got the cas fitted and attached today runs much much better guess the back pressure wasent just right. But now just moving on got to find a throttle cable that will work.
« Reply #130 on: July 29, 2010, 02:53:32 pm »
Lokar makes a univeral that alot of people have been using.
Offline 87OldYeller
« Reply #131 on: August 24, 2010, 06:13:04 pm »
What would be some good mufflers on this 5.3L Flowmaster 40 series? r anyone have a better suggestion? going for deep rumble, I don't like loud popping.
« Reply #132 on: August 25, 2010, 04:47:40 pm »
I like Magnaflows.
Offline Old77
« Reply #133 on: August 26, 2010, 09:55:11 am »
I've got dual exhaust on mine with the Flowmaster 40 series on them and I LOVE it!! With that said, they rumble really nicely at idle, cruising and moderate take offs but in the event you stomp on the go pedal they do tend to pop and crackle at those higher RPMS.
As Capt said, Magnaflows are also a good option and I've heard have less tendency for this so these may be a better option for you.
www.chevygmcofkc.org
Offline screamin86
« Reply #134 on: August 28, 2010, 11:56:21 pm »
i vote magnaflow thats my favorite muffler for a ls based vehicle. i run a single 3in exhaust on my 03 yukon with a 14in case magnaflow with dual 2 1/2 out exiting on the pass side and for now still running stock manifolds and cats its nice and mellow on the hwy and quiet at  idle and a monster at wide open throttle. ill be running the same muffler on my 86 trans am when i finish my swap in it.
http://www.youtube.com/watch?v=M_JtuY6dr6o
86 ta:lm7 hot cam boltons
