Author Topic: considering an 83 with 6.2 Diesel  (Read 4179 times)
Offline Gearhead1
  • Its not much, but its all I've got
« on: November 30, 2009, 02:20:03 pm »
I havent heard many people saying good things about the 6.2 Diesels...
Anything I should be concerned with? photos looks pretty nice, but its a big hike for me to look at it (100 miles) I need a good 2wd work truck/beater
this is the ad;
1983 GMC Sierra Classic 1500 6.2L Diesel Power Steering, Power Brakes, 3 Speed Automatic Overdrive Transmission, Cruise Control, Pulse Wipers, Air Conditioning, Power Windows, Power Door Locks, Tilt Steering, Rear Sliding Window,
There are many new parts that have been put on this truck just recently such as:
Brand New Starter
Brand New Water Pump
Brand New Injector Pump
Brand New Lower Rad Hose
2 Brand New Batteries /w Cables
Brand New Front Brake Pads
2 Brand New Front Brake Rotors
Brand New Steering Linkage
Brand New Front Wheel Wearings
Brand New Lower & Upper Ball Joints
Brand New Rear Brake Lines
Brand New Rear Brake Cylinders
4 Brand New Tires
2 Brand New Locking Fuel Caps
2 Brand New Fuel Tanks
+ 1 Brand New Spare Fuel Tank
4 Brand New Water Pump / Clutch Fan Studs
Brand New Oil & Filter
Brand New Coolant
No E-Test Required
This Truck is well maintained, Oil Sprayed, Body is in decent shape for the year and has true dual exhaust pipes out the side and the transmission was just rebuilt with a shift kit 3 years ago. The truck also just had a recent oil change and a coolant flush / change done on October 14, 2009.
The truck was just certified on September 18, 2009. This Truck Runs And Drives Great!
Asking $2500.00 obo or will trade for a Jeep or a 4x4 Diesel truck
« Last Edit: November 30, 2009, 03:11:28 pm by Gearhead1 »
Re: considering an 83 with 6.2 Diesel
« Reply #1 on: November 30, 2009, 03:36:24 pm »
There is nothing wrong with the 6.2L diesels, they aren't power houses, but they can pull down some great mileage.
Offline Mr Diesel
  • Aaron
« Reply #2 on: November 30, 2009, 08:33:18 pm »
It looks like they have done a LOT of work. Some of that stuff it can be a little hard to verify it has actually been done without crawling around under the truck, but it looks like they have taken very good care of it. $2500 would probably be a fair price for that truck in my area.
The 6.2 is a good engine, just not as powerful as modern diesels. Parts are much cheaper than modern diesels, and mpg usually better too.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
