Author Topic: rock sliders on single cab swb 80 truck w/ dual tanks  (Read 14367 times)
Offline lifted80gmc
« on: December 04, 2009, 01:06:10 am »
has anyone done this before?? if so how did u do it with the tanks?
Offline joesgarage71
  • Wrench
Re: rock sliders on single cab swb 80 truck w/ dual tanks
« Reply #1 on: December 04, 2009, 07:22:05 am »
 I seen where on other sites the guys mount a blazer tank in the back and buy the sliders from a toyo (cheap) and fab up brackets for the frame. Theres got to be some guys around Fallon whose trucks you can check out.
Offline lifted80gmc
« Reply #2 on: December 06, 2009, 01:18:32 am »
there is a pretty good site with some people locally that might help but not many full size trucks mostly jeeps
Offline NevadaNeal
« Reply #3 on: December 06, 2009, 02:50:28 pm »
Hey nieghbor..plenty of rigs around with sliders on..one trick i have seen is guys add a small body lift so they can relocate the tanks up more into the body.another option is a blazer gas tank. :)
Offline Chevalade
« Reply #4 on: December 06, 2009, 03:27:28 pm »
Sliders and saddle tanks are an oxymoron. They should not be used together. If you want sliders, relocate the tanks, if you want the tanks, don't use sliders. In the end it would be way less work, and way better design.
Offline campcrf
  • stroked
« Reply #5 on: December 06, 2009, 05:13:07 pm »
sorry guys... dumb question maybe.... what are rock sliders?
  thanks
Offline 4x4orbust
« Reply #6 on: December 06, 2009, 06:35:28 pm »
  thanks
they are basically structural nerf bars.  they keep the side/rockers of the truck from getting damaged when wheeling.
i was trying to figure out how to put sliders on my 82 SWB and can't with the saddle tanks there.  there wouldn't be enough support for the sliders to work properly only anchoring them front and back,  they need some support in the middle right where the tank is.
  • Wrench
« Reply #7 on: December 07, 2009, 08:35:13 am »
 ORD makes these hangers for the shackle flip
http://www.offroaddesign.com/catalog/shackelflip.JPG
Offline Chevalade
« Reply #8 on: December 07, 2009, 12:37:09 pm »
And how do these affect rock sliders?  ::)
  • Wrench
« Reply #9 on: December 07, 2009, 12:41:05 pm »
Oops wrong post
Offline campcrf
  • stroked
« Reply #10 on: December 07, 2009, 08:24:01 pm »
4x4.... thanks... i get it now.... duh
Offline lifted80gmc
« Reply #11 on: December 08, 2009, 03:06:55 am »
im in a bind
Offline Chevalade
« Reply #12 on: December 08, 2009, 09:15:43 am »
im in a bind
What seems to be the problem? Are you just looking for tank protection, or body protection? Do you need the capacity of both tanks? Why wouldn't a blazer tank in the back work, then you could build sliders?
Need more info on what you need.
Offline lifted80gmc
« Reply #13 on: December 10, 2009, 10:58:24 pm »
i am looking for body protection but dont want to do a blazer tank and like the dual tanks
Offline Chevalade
« Reply #14 on: December 10, 2009, 11:08:18 pm »
What are your plans for the truck? If you don't plan on rock crawling it, then some 3/8" plate skidplates should be plenty. Otherwise you can't have both, without sacrificing something.
