Author Topic: Gages  (Read 5454 times)
Offline Tazman
Gages
« on: December 07, 2009, 04:20:24 pm »
I have had my truck for some time and the voltmeter,oil and water gages have never really worked.All I did was put in some Autometer gages.I would like to get them working again.Does anyone know how to tell if the circut board is bad?Thanks
God BLESS AMERICA
Re: Gages
« Reply #1 on: December 07, 2009, 04:37:08 pm »
Check the fuse would be where I would start.  You might get lucky and that is all that's wrong.  Sometimes you can see a problem with a circuit board, sometimes you can't.  I had a bad one effecting my gas gauge when the lights were on.  $35 later at the local pick n pull I landed a new one with a quartz clock in it.  I put all my gauges back into the truck because I knew how they read..
Offline Tazman
Re: Gages
« Reply #2 on: December 09, 2009, 07:29:21 am »
Thanks
God BLESS AMERICA
Re: Gages
« Reply #3 on: December 09, 2009, 11:18:56 am »
If you want to check the circuit board, pull the cluster out and turn it over.  If it is broken or burnt, it will be obvious.
