Author Topic: big block swap in a 1977 k-20  (Read 7270 times)
Offline olblue2
« on: December 11, 2009, 11:56:36 pm »
ok guys tell me if a big block chevy will fit up in my 1977 k-20 4x4. it has the m-20 muncie 4 speed.  will it fit up with no problems???
« Last Edit: December 12, 2009, 12:05:09 am by olblue2 »
Re: big block swap in a 1977 k-20
« Reply #1 on: December 12, 2009, 12:10:06 am »
 In line six to a big block are the same bellhousing bolt pattern.
Offline olblue2
« Reply #2 on: December 12, 2009, 12:11:09 am »
ok cool but how about the motor mounts? any changes need made?
« Last Edit: December 12, 2009, 12:31:11 am by olblue2 »
Offline Engineer
« Reply #3 on: December 12, 2009, 08:32:51 pm »
You can use your small block motor mounts, but there are big block specific mounts as well. If you are looking to go with BB motor mounts just ask, and I will post the OE part number. Otherwise use your SB mounts.
The only issue I had using the SB mounts on a BB was the fact that the fan hit the lower portion of the fan shroud, and if you are using Hooker headers, they may hit the frame if using the SB mounts.
All Chevy bell housings use the same bell housing bolt pattern.
If your BB is a 396~427 you can even use your SB flywheel. However, the 400SB, and 454 are extenally balanced, and you should only use those engine's flywheels on those engines specifically.
Also, even though the 400SB, and 454 are both externally balanced, their flywheels will not interchange with each other.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline olblue2
« Reply #4 on: December 13, 2009, 12:46:07 am »
cool , well the fan wont be a problem im running a electric fan, so if i get a new flywheel will i have to get a new clutch and pressure plate?
« Reply #5 on: December 13, 2009, 02:06:14 am »
you dont have to but you might as well. same some trouble down the road
Offline olblue2
« Reply #6 on: December 13, 2009, 10:24:17 am »
clutch, pressure plate and flywheel all are new and have only few miles on em
Offline 1980c10
« Reply #7 on: December 13, 2009, 10:48:44 am »
I have had problems switching to an externally balanced engine due to bell housing clearance, becuase of the increase in flywheel thickness. I'm not sure if it might apply here or not.
