Author Topic: uneven lift kit  (Read 5317 times)
Offline derrick79
uneven lift kit
« on: December 21, 2009, 05:03:53 pm »
Hey guys,
So I FINALLY got my hands on one of these old square bodies. Its a 76 k25 sierra grande. My only problem with it is that the guy I bought it off put a 4 inch lift on it but it sits a bit slanted. The front seems to be an inch or two lower. i have been told that with these old leaf spring lifts you have buy one that is a bit higher in the front rather than even all around so it levels out. This true? I'm planning on replacing the lift with a 6 inch anyway, anyone think 37's will fit with the 6 inch? Or should i leave the 35's on it?
Thanks
Offline 4x4orbust
Re: uneven lift kit
« Reply #1 on: December 21, 2009, 05:31:59 pm »
the lifts i have installed are usually the same way.   the front is lower than the rear.   i guess they expect you to always have a load in the bed to level it out.   the springs also sag over time, not sure how old yours are.
with a 6 inch lift, the 35's would look fine.   you could get away with the 37's if you want to trim the fenders some for clearance.
Re: uneven lift kit
« Reply #2 on: December 21, 2009, 07:56:38 pm »
in order to get the front nd rear to match up you couple make some front shackels a bit longer than stock Fitz on here has don that i plane to but haven't yet, and with only 6" 35 will fit just right anything more you need to trim
