Author Topic: window motor issue  (Read 12535 times)
Offline infamouschevy
window motor issue
« on: December 28, 2009, 12:27:33 pm »
 ??? well i changed the window motor in my cousins 86-c-10 passenger side when i put it in the first time i was working fine then it just stopped so we figured it was the motor took it back to auto zone got it swap out and came put the other 1 on and the same thing happened so i went took the switch off my truck for the window and that didn't work does anyone know what else it could be.
infamous chevy
Offline chevyman72
  • 1987 C10 2WD 350cid 700r4
Re: window motor issue
« Reply #1 on: December 31, 2009, 06:25:06 am »
Process of elimination...I dont know how far you troubleshot. I would start by checking if there is actually 12 volts to the switch. if so..then press the switch and make sure 12 volts is leaving the switch. If 12 volts isnt to the switch you will have to go back the other way. fuse or wire....With you moving the motor and wires around durring replacement you might have pulled something between the switch and the motor. If 12 volts is leaving the switch to the motor then with the button pressed you need to check at the motor connection for 12 volts. You might want to get a Haynes book from Auto zone for your truck. They have some helpfull drawings in there. I have window motor problems but mine are 22 years old. I am fixing to be replacing my motors to. Does Auto zone require a core for these units? Hope this helps. You are probably a better troubleshooter than I a ever knew but this is a start. If it was just working, I dont see a big problem. I would say the 12 volts isnt making it to the motor due to a connection or pulled wire.
Chevyman
