Wheels & Tires
wheel nut and stud problem
Topic: wheel nut and stud problem (Read 9968 times)
hag77
January 02, 2010, 07:20:47 pm »
went to take the wheels of my 82 1/2 ton 4x4 and the lug nut just spins and will not back off any tips on removing
choptop
Extended cab fanatic
Re: wheel nut and stud problem
January 02, 2010, 09:37:59 pm »
try to tightened it with an impact to see if it will grab any splines left in the lug, and then try to take it off with the impact. Is it on a steel wheel, or aluminum?
hag77
January 03, 2010, 09:09:48 am »
its a steel rim i will give that a try when it warms up i got about 5 that won't come off
bfofish
Too Many Toys..... Not Enough Time
January 03, 2010, 09:24:25 am »
Sounds like you might have the lugs that have the cheap chrome cover over a steel lug.
If this is the case you will have to rip the cover off and then you can loosen the lugs.
hag77
January 03, 2010, 09:39:32 am »
nope i got the open end type
January 04, 2010, 12:42:37 am »
you could try to break it off, put a socket w/ extension or a 4 way then step on it till it breaks or give it a shot with a hammer but you might hit the rim with that
smitty77
January 04, 2010, 04:14:49 pm »
Suppose you could use a nut splitter as a last resort..... I'd try the tighten-loosen trick first.
4x4orbust
January 04, 2010, 04:35:25 pm »
if all else fails, and you suspect the stud to be stripped, you could drill it out...
1982 chevy K-10 SWB, 355 th350/np208. 2.5"lift, 33" swampers, headers/duals, current project
January 04, 2010, 04:47:35 pm »
i know i said this before but you could take off all the lug nuts and drive it till the wheel falls off.
j/k the nut breaker sounds like a good ideal. there was a nother form on here i forget what its subject was but they took a grinder i think to the wheel
Layne
January 04, 2010, 05:23:29 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=14268.0
January 05, 2010, 12:36:35 am »
thats it thanks layne
Layne
January 05, 2010, 04:59:09 pm »
Good for a laugh, but I hope we don't have to get to that!
Wheels & Tires
