Author Topic: lug nut question need help quick  (Read 4069 times)
Offline jamiebarnesjr3
« on: January 04, 2010, 09:56:04 am »
i just picked up a set of wheels for my 84 k10 but cant figure out which lugs to use to mount em. they have 2 inch deep holes in the rim where the nut goes on but heres the kicker the for way or ratchet will not fit in the hole to tighten the lugs up. i tryed using the longer studs from my old mag wheels with the shaft that slips through the rim but the shaft didnt fit through the whole so that tells me i need to use acorn style but like i said i cant get nothing in the hole of the rims to tighten them up
Re: lug nut question need help quick
« Reply #1 on: January 04, 2010, 11:03:15 am »
Get lugs from Autozone that are smaller than what you currently have.  Longer studs won't help if the seat is inside the 2" hole.
