Author Topic: 84 K-10 Silverado  (Read 6240 times)
Offline 84silveradok10
84 K-10 Silverado
« on: January 07, 2010, 08:35:25 pm »
I recently bought a 84 k-10 silverado. I believe it is all stock except for the distributor and coil, 4 inch rough country lift, a set of 35x12.50x15 BFG KM2's. It has a 10 bolt front axle and a 12 bolt rear axle, with what I believe to be stock gears.  :( The gears are way to tall for the tires, ( I don't have a tach but at 65 she is chugging at real low rpms and could almost downshift, so I'm thinking of going to 4.11 or maybe 4.56 gears. I have a 700r4 with o/d, any opinions? This is my daily driver as, well as my play toy.
84' K-10 Silverado Shortbed
350, 700R4, 10B Front, 12B Rear
Accel HEI Ignition
4" Rough Country Suspension Lift
35" BF Goodrich KM/2
Offline flat black
Re: 84 K-10 Silverado
« Reply #1 on: January 07, 2010, 08:49:29 pm »
4:11s  would prob be good with the od trans and 35s...
Offline team39763
« Reply #2 on: January 07, 2010, 09:21:26 pm »
Did you make it out of that(in the second pic)?
« Reply #3 on: January 08, 2010, 05:10:46 am »
O yeah I made it out, fine from that hole. The whole thing was as deep as you see in the rear. I just pulled the front end out so I could hop out of the truck to take the pic. Those bfg mud terrian km2's really grip well.
Accel HEI Ignition
