Author Topic: 85 3/4 ton 5 speed swap  (Read 19100 times)
Re: 85 3/4 ton 5 speed swap
« Reply #15 on: February 17, 2010, 02:43:55 am »
The hanger, and brake pedal will work, but you will need the clutch pedal from a juice clutch truck.
Offline heavychevy
« Reply #16 on: February 24, 2010, 03:49:28 pm »
ok i have my pedal and new tilt colum installed, im gettin ready to swap the trans this weekend ,do i use the nv4500 bell housing with an 86 slave cylinder cause the oe z71 cable is som plastic crap
Offline heavychevy
« Reply #17 on: March 05, 2010, 11:09:05 am »
grandfisher what bellhousing did u use the stock 93 nv4500 or a sm465 ,and what slave did u use
Offline heavychevy
« Reply #18 on: March 06, 2010, 10:36:52 am »
does any body know what bellhousing and slave to use
« Reply #19 on: March 06, 2010, 02:03:40 pm »
Use the one that's associated with the trans you have.
