Author Topic: 15X12  (Read 4739 times)
Offline FIRELS1
15X12
« on: January 10, 2010, 09:10:34 am »
I have an 86 k-10 w-6 in. suspension lift.  I want to run 15X12 rims, what back spacing do I need?  Also, would it be a problem to run a 35x13.5 tire w/o rubbing or do I need to go w/a 35x12.5 tire?
Re: 15X12
« Reply #1 on: January 11, 2010, 03:16:24 pm »
It is BEST to measure you current setup, If you want an estimate, 4" BS should be good, as for rubbing the 12.50 should be ok for the most part.
