Author Topic: Budjet Building a 10 Bolt Axle  (Read 3862 times)
Offline autorepr
« on: January 13, 2010, 09:10:24 am »
I saw a posting here asking about building a 10 bolt or upgrading to a stronger
axle. I looked back and can't find it so I'll add this new thread.
While in the out house clearing out my inner most soul I saw an article in the March 2006 Car Craft Magazine where they "budjet built" a 10 bolt axle. There is some pretty good info in it on housing ID, axle shaft upgrade and posi unit etc. It's geared towards building a car axle but it's similar in concept.
Offline team39763
Re: Budjet Building a 10 Bolt Axle
« Reply #1 on: January 18, 2010, 11:38:34 pm »
Got a link to it?
Offline team39763
« Reply #2 on: January 21, 2010, 09:31:37 pm »
Well I'll post what I've read about beefing up the 10 bolt.
Use a solid pinion spacer rather than a crush sleeve
Use higher splined axles if you can - 33 spline axles and 33 spline spool
use diff cover with lugs on the sides for utilizing braces
Don't use excessively loose backlash
Weld the tubes to the housing
I plan to do most of that.
Offline SUX2BU99
