Author Topic: Cut-out flares  (Read 3599 times)
Offline krafty33
Cut-out flares
« on: January 13, 2010, 09:21:08 am »
I was thinking about putting cut-out flares on my 76. Do you have to remove the wheel well or is there enough room for the cut out to be placed and still able to retain the wheel well.
Re: Cut-out flares
« Reply #1 on: January 13, 2010, 01:05:12 pm »
It depends on how much you need to cut. Look at the wheel well and locate the bolts holding it in. It should give you a estimate if you need to or not. Can always obtain a set of install instructions before you buy the flares.
Re: Cut-out flares
« Reply #2 on: January 13, 2010, 07:13:35 pm »
I have installed several pairs of them. You only cut off the outer fender on the ones I did.
