Author Topic: rear end gears  (Read 4664 times)
Offline krazylunatic
rear end gears
« on: January 18, 2010, 02:48:14 pm »
Is there anyway to tell what gears a rear end has without taking the cover off, maybe running the vin number or something somewhere? also im new to chevys but is a 12 bolt stronger then a 10?  im wanting some different gears and figured i might as well beef the whole rear end up
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: rear end gears
« Reply #1 on: January 18, 2010, 08:07:00 pm »
RPO codes should be in you glove compartment...if you never replaced the glove comp.  RPO code will tell (via a code you can pull up on the internet) what the ratio is.
There is, according to some, a stamp on the axle tube --passenger side of hogs head on the tube facing the front...some kind of stamped/engraved ratio on that.
there is also the old fashioned way to approximate the rear ratio by jacking up the rear and marking a tire with chalk.  Turn the drive shaft and count how many times you turn it for each revolution of the tire. Divide the numbers together....driveshaft revolutions / rear wheel revolution. It should get you close to say 4.10, 3.73, 3.08, etc...
Re: rear end gears
« Reply #2 on: January 18, 2010, 08:12:30 pm »
VIN won't tell the gear ratio.  If the cover hasn't ever been pulled and the oil replaced now is a good time.  The RPO is the only option, but keep in mind that someone may have changed it.  That is why it is only guaranteed if you pull the cover.
Re: rear end gears
« Reply #3 on: January 19, 2010, 01:36:10 am »
like capt said the only sure way to know if you pop your cover but if you know your speed, rmps and tire size there is a formula you can use
if your running 50 mph @ 2k w/ 38" then
your ratio would be about 4.53
rpms x tire size / 336 / mph = ratio
2000 x   38    / 336 /  50    = 4.53
http://forum.73-87chevytrucks.com/smforum/index.php?topic=10879.0
