Author Topic: 305 Overheating  (Read 35911 times)
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: 305 Overheating
« Reply #15 on: January 29, 2010, 11:18:24 am »
Quote
just remove the t stat and see what it does
That doesn't work because then the water doesn't stay in the radiator long enough to cool off.
or it's too cool and wont get a chance to get hot.
It will help diagnose if there is a clogged port or something or bad water pump.
Offline jaredts
Re: 305 Overheating
« Reply #16 on: January 29, 2010, 11:53:00 am »
I'm confused.  Without a thermostat it won't stay in the radiator long enough to cool down?  I've never heard that.  Does removing the thermostat really increase the flow rate that much?  Even if it does it just seems counter-intuitive that increased flow would decrease cooling.  The radiator is full either way and under the same pressure either way, so I just have a hard time wrapping my brain around that.  Can someone explain the theory behind this?  If you took an operational vehicle and remove the thermostat it will run hotter?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: 305 Overheating
« Reply #17 on: January 29, 2010, 01:34:11 pm »
read my post again.
I think it becomes more free-flowing therefore it won't really get warm enough to even get your heater working well.  Coolant won't stay in the engine long enough to warm up.  At least that is my experience and I have run engines w/out t-stadts a few times when needed to prevent overheating.
Re: 305 Overheating
« Reply #18 on: January 29, 2010, 03:35:54 pm »
iv heard of both a it will cool too much and b it will not cool enough but if you gut it it will slow it down enough to cool it. but anyway forget about that test your old one in the pot and see what it does. how long does it take to warm up? after start up
Offline jaredts
Re: 305 Overheating
« Reply #19 on: January 29, 2010, 06:54:48 pm »
Sgt.:  sorry I should have quoted him so it wasn't confusing.  I was asking about Jim's statement that without the thermostat the coolant wouldn't stay in the radiator long enough to cool off.  Nevermind, though.  That's a tangent.
Offline Jim Rockford
  • Banned
Re: 305 Overheating
« Reply #20 on: January 29, 2010, 08:43:12 pm »
it will eventually overheat , because it doesn't get a chance to cool is what i should have said. Will take forever to warm up at first though.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Re: 305 Overheating
« Reply #21 on: January 29, 2010, 09:25:20 pm »
Taking the T-stat out and making it hotter because it's not in the radiator long enough?  ???
Heat goes to less heat. It's heat energy that is released at the radiator, the coolant is the means of tansfer. If the radiator is cooler the coolant will be cooler.
Offline Flashback
Re: 305 Overheating
« Reply #22 on: January 29, 2010, 10:49:30 pm »
Well guess I'll try switching out the t-stat again. What is the ideal temp unit to get? No A/c, but I do tow cars with this thing. The thermostat I put in was a BNIB Napa 195 degree unit, tho it had been sitting in the glovebox for at least a year.
Oh and it does warm up pretty quick. Seems to be a lot of air trapped in the upper hose. How can I bleed that out?
1983 Malibu Wagon|TPI 305|T5 5 speed|3.73 non-posi
1992 Honda Accord Wagon|SOHC|5 speed|Gude Cam
1986 Chevrolet C10|305 V8|SM465|Shortbed|Custom Deluxe
Offline Layne
Re: 305 Overheating
« Reply #23 on: January 29, 2010, 11:19:44 pm »
195 is good. Idle it cold with the cap off for a min and add coolant I believe to get those air pockets out.
Re: 305 Overheating
« Reply #24 on: January 29, 2010, 11:58:21 pm »
X2 on the filling up while running, when you pretty quickly you talking about 5 min or what
Re: 305 Overheating
« Reply #25 on: January 30, 2010, 07:27:47 am »
Did you check the flow? Did you check the radiator? AS far as bleeding the system everyone here needs to get one of these http://www.tooltopia.com/lisle-24610.aspx?utm_source=googlebase&utm_medium=cse&utm_term=LIS24610&utm_campaign=googlebase_18u
You just put it on the neck of the radiator and allow the engine to reach operating temp. The coolant level will rise and fall as air is released and the t-stat opens. You won't spill coolant everywhere and can be sure the system is full. When it's full shut the truck off squeeze the upper hose and install the plug stop. Release the upper hose and remove the funnel. Saves huge mess from happening.
Re: 305 Overheating
« Reply #26 on: January 30, 2010, 07:52:30 am »
Ive had to deal with this one before. In cooler areas, the thermostat removal isn't as drastic because there is more temperature drop across the radiator anyway, but it does lead to overcooling. In hotter environments, such as where I live, its not as forgiving. Ive dealt with this primarily on industrial engines, but have also experienced similar problems on a few trucks way back when. Its known that the t-stat holds the coolant in the block long enough to get it hot, and then lets it flow to the radiator. Now, once the slug of cooler coolant hits the tstat it closes and starts the process all over again. (I know alot of you know this, so please don't take offense, some don't) There is normally a 20-40 degree temp drop from the top to the bottom of the radiator depending on the size of the radiator, and ambient temp, etc. Now, with the t-stat removed, the beginning results in overcooling, then can lead to overheating depending on ambient temperatures. When the t-stat stops the coolant in the block to exchange the heat there, it also stops it in the radiator to exchange it there. If the coolant doesn't stop in these two areas long enough, then the block will not be getting the heat removed from it, and the coolant will not be getting as much heat removed from it in the radiator. It has to pause long enough to exchange the heat, even if its just a few seconds.
  Ran into this on a hot summer day on an industrial Cat engine. Differential temp from top to bottom of radiator was 5 degrees, no enough exchange because the engine increases more than that, and eventually it would overheat. Good pressure from water pump, clean radiator, good air flow, then found out customer removed t-stats for reasons unknown. Replaced them and engine never saw above 190. Side note, this engine would run about 2 hours before it would overheat after it reached 185 degreesF
« Last Edit: January 30, 2010, 08:06:16 am by choptop »
Re: 305 Overheating
« Reply #27 on: January 30, 2010, 07:55:26 am »
Sorry so long guys, I just hope it helped someone. I forgot to mention, I havent had an issue with the tstat removed on days under 80 degrees F, but the days I did, the temps were over 100 degrees. Ive also got a 4 core radiator in about everything I own, and a smaller one would loose even less heat with out the t-stat there to stop it for at least a brief time.
« Last Edit: January 30, 2010, 07:57:26 am by choptop »
Re: 305 Overheating
« Reply #28 on: January 31, 2010, 02:43:40 am »
i think its more of a prob on newer cars with were the temp sensor helps out with gas and all
Offline Russ130
Re: 305 Overheating
« Reply #29 on: February 05, 2010, 05:33:34 pm »
Are you getting heat?
