Body, Glass & Paint
Where to start
Topic: Where to start (Read 9126 times)
bboyd
Where to start
January 22, 2010, 02:18:08 pm »
Ok guys i need some help here on where to start, Im about to get going on my cab(saved the best for last) and i need to replace all the common stuff (rockers,cab corners,and inner rockers) but im not to sure where i should start i was thinking i should just cut out all the old and start at the inner rocker then the rocker and finish with the cab corner?my experience with body work is very little and the last guy that showed me how to do this said to pop rivet it over the old stuff
and well i was young and gullable so i did,just incase you dont already know thats a really bad idea
any help is much appreciated thanks
also i would just like to say 73-87 chevytrucks is the best site ever it has saved me tons of time and money... keep up the great work capt
I swear i was just going to put a new motor in but...
jaredts
Re: Where to start
January 22, 2010, 02:53:17 pm »
I agree, this is the best site ever. Search this site for info. Almost everything you need is here. I am basically finished with one side of a similar cab repair. I couldn't have done it without a few key people's input from this site. In short you need to cut everything out, trim new panels, and screw everything in place. Check door fit and weld only once every piece has been verified. The cab corner does go on last. You didn't mention cab floor support. If you haven't checked that out yet you might want to have a look. Another sneaky one is the footwell. Mine looked perfect until I looked closely at where it met the floor. One of the biggest challenges is getting up to speed with tools and welding skills if you don't already have that. This is the best post to start with, although there are others:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5661.0
bboyd
Re: Where to start
January 22, 2010, 04:21:18 pm »
Thanks jared i had never even thought about screwing them together first but that sounds like a great idea, i already have the cab floor support aswell just waiting to get some buddys out here to help flip the cab, i just read that post and it looks asthough all the old metal was left on to do that,i dont reeally want to do that it makes a spot for the metal to rust from the inside out
Last Edit: January 22, 2010, 04:34:57 pm by bboyd
Re: Where to start
January 22, 2010, 09:49:34 pm »
Leaving good metal in is fine. There is no reason to replace a whole section if you don't have to.
jaredts
Re: Where to start
January 23, 2010, 08:04:30 am »
I'm not sure if I know what you mean by "all the old metal was left on to do that". In the post they cut out what was not sound. Nothing more. You definitely don't want to use the entire rocker panel if you don't have to, for example. On the other hand never weld to rusty, thin metal. Its always a judgement call.
Blazin
Blazin new trails!
Re: Where to start
January 23, 2010, 10:48:55 am »
When it come to floors etc. I cut out the bad, and trim the new panel to fit about an 1/8 to a 1/4 bigger. As for rockers. I replace the whole thing 99% of the time even if its only rotted part of it. 9 times out of 10 there is more rust than you can see. But welding is the best but not a must. On a restoration job to a pristine show car yes, but for what most of us are looking to achieve a slight over lap works fine.
bboyd
Re: Where to start
January 23, 2010, 04:19:27 pm »
Jarred i was talking about the cab corner at the bottom where he screwed it on, there must have been old metal left in behind that to screw it to.
Blazin
Blazin new trails!
Re: Where to start
January 24, 2010, 01:18:03 am »
The inner cab corner.
bboyd
Re: Where to start
January 24, 2010, 06:54:35 pm »
the inner cab corner? on the bottom? mine doesnt have an inner cab corner that goes all the way to the bottom it must have been cut out in one of the previous patch jobs
Blazin
Blazin new trails!
Re: Where to start
January 24, 2010, 09:41:27 pm »
Most times you have to replace them too.
1980c10
Re: Where to start
January 26, 2010, 09:04:11 pm »
I would start by removing the seat and carpet to see how your floors look. also look at your cab mounts.
bboyd
Re: Where to start
January 27, 2010, 06:23:29 pm »
ya the seats and carpet are long gone thats all ok and like i already said in a previous post i already have new cab mounts and the support aswell but thanks c10
Body, Glass & Paint
Where to start
