Author Topic: Fuel Delivery  (Read 6225 times)
Offline ipetero
Fuel Delivery
« on: January 23, 2010, 05:13:17 pm »
Hello everybody, again.  I was wondering if someone could direct me to a link on fuel delivery.  I have an 87' R Series, 2WD that I had to put a motor in...  A carburetored motor.  It does have two fuel tanks and I am using only the passenger side tank (because the switch does not work).  I think i might have burned up the intank fuel pump(s).  I never had a return line hooked up to my carb...  Since I put the motor in, it has always had a mechanical fuel pump.  I did however try to play with the electronic pump, and thats when i think i might have burned it up, and it always had to much pressure, (fuel spilling out the side of the double pump).  I did not know what else I needed to use the electronic pump.  There is no plan on going to fuel injection...  So I was wondering, should I replace the intank electronic fuel pumps to carbureted pumps or keep what I have?  Everytime the truck has been sittin for a couple days, I would have to prime the carb to start it...  And when it does start and run (after I prime it), she runs fine, idles fine, and drives fine.  And I would also like to fix the duel tank switch if and when i can figure out my fuel delivery.  Some help from anyone would be much appreciated! Thank you.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11923.0
tear it up ! !
Re: Fuel Delivery
« Reply #1 on: January 23, 2010, 05:33:27 pm »
If you plan to use Carbs I would drop the tanks and put in non-EFI sending units and reroute the lines.  If you plan to use the electronic in tank pumps you will have to put a regulator on it and return all the fuel to the tank via switching valve because the pump puts out 18lbs and a carb only needs 5lbs.
Offline ipetero
Re: Fuel Delivery
« Reply #2 on: January 23, 2010, 05:48:25 pm »
How do I test the units that I have to see if there salvagable? And if there not what kind of units do i need, three or four inlet??
tear it up ! !
Re: Fuel Delivery
« Reply #3 on: January 23, 2010, 10:47:49 pm »
Which why are you going?  Intank or not?
If you plan to go with just a block mounted pump, just get a 2 outlet sending unit (3 outlets, supply, vent return, vent.
Offline ipetero
Re: Fuel Delivery
« Reply #4 on: January 25, 2010, 10:59:41 pm »
Yeah, i'll probably stick with the machanical pump and get some new intank sending units. I am adding a few pics because a few months back I changed engines. That half fast race engine was just too much!!! That and it is a great runner toO! Nothing purdy, just easier on the wallet.
So where would i start on my tank selector problems??
tear it up ! !
Offline team39763
Re: Fuel Delivery
« Reply #5 on: January 26, 2010, 06:26:16 pm »
Them flames sure do make that truck stand out...in a good way.  Can you get a pic of the truck with the hood closed?
