Author Topic: Dropping the passenger gas tank on my 86 350  (Read 3651 times)
Offline lbrowne
« on: January 28, 2010, 02:32:52 pm »
It has a nasty leak and I'm going to either fix or replace the tank.
I read through this procedure:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9294.0
About how far down can the tank come with the sending unit and fuel lines still attached? I know the tank is already empty, thank God I caught most of it with several buckets.
Thnx,
lbrowne
1986 GMC Sierra Classic
My first truck! (completely stock...for now)
Offline 4x4orbust
Re: Dropping the passenger gas tank on my 86 350
« Reply #1 on: January 28, 2010, 02:56:46 pm »
if the tank is empty you can just start dropping it untill the lines come taught.  if you lower it slowly you will see the what i mean.  also, when you go to remove it, sometimes it's easier to cut the rubber lines that connect from the sending unit and just replace them than it is to hassle wit disconnecting them.
Offline lbrowne
« Reply #2 on: January 28, 2010, 03:31:20 pm »
I guess given the age it would be better to just replace them anyways! Cheers!
« Reply #3 on: January 28, 2010, 05:21:03 pm »
I put a jack under the rear portion and lower it down enough to remove the lines/wires.  In that link, it is as low as it would go.
