Author Topic: Classic dash replacement instrument cluster.  (Read 12492 times)
Offline K20Wulf
« on: February 03, 2010, 01:52:11 am »
Found this on the web, it's expensive, but really cool!
http://www.classicdash.com/shopping/product.php?productid=387&cat=192&page=1
86 K20 4x4
7" lift, 35's
350/400/208
Re: Classic dash replacement instrument cluster.
« Reply #1 on: February 03, 2010, 02:10:03 am »
from Chris's shop
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=VFD3-73C-PU&Category_Code=7G
you can find and make your own cheaper than that one you found i think in flamin on here has made one along with others but his i can remember right off hand
« Reply #2 on: February 03, 2010, 02:13:06 am »
Those are expensive, but it comes with the gauges. You can order it without them as well. I saw them at the Goodguys car show and I would not spend the money on them. The plastic is really really thin.
I also personally think that adding aftermarket gauges to a stock brushed aluminum bezel as well as the Dakota Digital setup look better.
Offline K20Wulf
« Reply #3 on: February 03, 2010, 02:06:29 pm »
I really don't like the look of the digital one at all, too cold and lifeless. I was thinking if you had the skills and tools, you could just buy a blank sheet of aluminum and make your own.
86 K20 4x4
7" lift, 35's
350/400/208
Offline mrboyy17
« Reply #4 on: February 03, 2010, 02:54:23 pm »
hey check out these two links on making your own version for probaby cheaper that 949.  anyways just a thought
mark
http://www.73-87.com/7387garage/interior/gauges_recessed.htm
http://www.73-87.com/7387garage/interior/gauge_surface.htm
« Reply #5 on: February 04, 2010, 11:02:25 am »
The Covan you listed above is junk in my opinion for the exact reasons beastie_3 posted.  They have come up a lot on the forum.
I would suggest building your own like the links mrboyy17 posted.
