Engine/Drivetrain
wonderin if i could put a hydraulic clutch in my truck
Topic: wonderin if i could put a hydraulic clutch in my truck (Read 7248 times)
k5blazerfan
K5 blazers will never die
February 04, 2010, 01:52:06 am »
i got an 84 blazer with a non hydraulic clutch and i want to put in a hydraulic clutch...could any hydraulics of any other chevy truck fit?
Don't forget the tow chain!!! Might have to tow a ford home!
Blazin
Blazin new trails!
Re: wonderin if i could put a hydraulic clutch in my truck
February 04, 2010, 05:48:09 am »
Allot of effort for nothing gained I would say. It can be done pretty easily. Would have to take the bell housing, slave cylinder, line, reservoir, master cylinder / rod assembly, and pedal from a C/K with a juice clutch.
frito-bandito
Hillbilly Deluxe
February 04, 2010, 07:34:55 am »
if you put a hydraulic clutch in your truck, it would make it easier and cheaper to do a NV4500 (5 spd OD) swap in the future if so desired.
k5blazerfan
February 04, 2010, 10:58:28 pm »
thanks blazin and emc im thinking of a hydraulic clutch because i would like to someday soon put in an nv 4500 5 speed cause the gas mileage would improve... that and my non hydraulic clutch is really really springy itll knock you out of your chair of you aint caerful lol
February 05, 2010, 08:20:54 am »
Springy as in stiff? if so that is probably because it has a 3 finger clutch in it. If you change to a diaphram it will be much easier.
Engine/Drivetrain
