Author Topic: Leaf spring length?  (Read 5338 times)
Offline K20Wulf
Leaf spring length?
« on: February 09, 2010, 07:02:27 pm »
Does anyone know what the stock spring length on a 86 3/4 ton long bed is (front & rear)? It has a 4" lift on it and I'm not sure if the springs on it now are longer or not. My basis for this question is; I was told I could put 52" springs up front and get 5 to 6" of lift. Also I want to do a shackle flip in the rear, but have no idea what length springs I have. Any help would be great. :)
86 K20 4x4
7" lift, 35's
350/400/208
Offline Chevalade
Re: Leaf spring length?
« Reply #1 on: February 09, 2010, 08:14:40 pm »
52/56" in the back...check with tape measure. And fronts should be 48" I do believe. And yes there is a kit to put 52's on the front, and it would actually net you approx 3.5-4" of lift. Combine that with a shackle flip in the rear, and you should sit fairly level.
