Author Topic: Speedometer problems  (Read 4068 times)
Offline 4x4HighSierra
  • Sqaure body stud
« on: February 11, 2010, 05:55:17 pm »
Hey guys i know this isn't close to a Chevrolet but i was needing some help.  I have a 2002 Dodge Neon sxt.  This last saturday i replaced the battery and ever since then the speedometer has spun around and is on the bottom side of the needle stop.  My first thought was the VSS went bad.  I don't think the gauge cluster has gone bad bc it is the only gauge acting up and the odometer inside the speedometer still works.  If anyone has any intell on this dilemma that would be great.
1985 GMC High Sierra K10 mild 350 and rebuilt 700R4 with transgo shift kit
1985 GMC Sierra Classic C10 TPI 350 swapped in and 700R4 and 6 inch drop, with front drop spindles and a axle flip in the back and c notched frame
1995 Chevy Tahoe LT stock
Offline frogman68
Re: Speedometer problems
« Reply #1 on: February 11, 2010, 06:22:55 pm »
Hold the Trip reset button down then turn the key to the on position (not cranking)
That worked for my sisters Voyager.
  • Sqaure body stud
« Reply #2 on: February 12, 2010, 10:53:55 pm »
Thanks for the reply.  But today at work i took the dash apart and found the gauge cluster only half plugged in.  It was an easy fix but with changing the battery and then the gauge acting up it made it sound like a sensor or gauge went out.  ;D
