Author Topic: How much paint?  (Read 30259 times)
Re: How much paint?
« Reply #15 on: February 16, 2010, 06:38:26 am »
I have used Kirker in the past. It doesn't hold up over time. A couple years down the road it checked and chalked.
Offline jaredts
Re: How much paint?
« Reply #16 on: February 16, 2010, 09:05:15 am »
Darn, I kinda had my eye on kirker single stage.  I had heard bad things before, so I wasn't sure.  Blazin, you like Nason and Omni?  Do you lean toward one or the other for a budget paint job that still needs to last ten years?  When I briefly worked in auto body, the pros I worked with always bought Dupont for some reason???  Is Dupont worth the money compared to their budget Nason line?
Offline 80stepsideguy
Re: How much paint?
« Reply #17 on: February 16, 2010, 12:15:53 pm »
Nason is actually made by dupont.I used nason for awhile and it is good paint.I sprayed a cougar i once owned in kirker single stage blue metallic.Came out really nice.But i would prefer nason to use for single stage paint.
thanks
pat
1998 Chevy 1500 S/B 2wd
Re: How much paint?
« Reply #18 on: February 16, 2010, 08:29:56 pm »
I am a Dupont man, so the Nason is more like Centari etc. I worked for a guy years back that swore by PPG single stage. I never thought it had the pop Centari with 793 hardener had. That being said the Omi acrylic enamel on my 55 is holding up pretty well for a quickie spray job. It wasn't to bad to use either. I added flattening agent to it as I wanted it more of a satin finish. either of them will be good for what you are looking at doing. A budget job probably won't last ten years!!
Re: How much paint?
« Reply #19 on: February 16, 2010, 09:30:33 pm »
I just bought a gallon of paint and a gallon of clear for my mutt today. $425 but it's worth it.
Re: How much paint?
« Reply #20 on: February 17, 2010, 02:22:22 am »
What brand vile??? Going to need a bit more of clear for the truck i think 1 gallon wont get you far...
thanks
pat
Re: How much paint?
« Reply #21 on: February 17, 2010, 02:39:04 am »
X2 on both!  ;D
